I have successfully downloaded and unzipped the files and loaded them into CM. I have committed them. I followed the grey line all the way to both ends, I think I know where VC is.
Great job!! If you don't mind I am going to use this. As I have said before, you have where the track should go with the grey line, from here I can start placing track. What a start for me.
A couple of question I have:
1. Were these historical images you used? What year??
2. You mentioned in your post of Friday, Nov 16th, the map view, I can not seem to find it in Surveyor?? I think I am missing something.
I just want to thank you so much for this, it means a lot to me. If you ever need any photos of this area just let me know.
Bruce
Caboose No 9 Download
Re: Caboose No 9 Download
Good news!
On my system, the mini map is available through the main menu tab on the upper left of the screen in surveyor.
The imagery is relatively current; probably within the last year or two.
I look forward to seeing some of your progress!
I found the mini map, it was in the menu in surveyor.
Sometimes my brain doesn't work. The reason I asked it the imagery was current is that if it was from historical imagery I wouldn't recognize anything. But, since it is relatively recent I should be able to recognize the area. I will zoom in on the mini map to figure out where I am.
I will work on that over the Thanksgiving Holiday and let you know how I make out.
Have a great Thanksgiving!!!
Again thanks for your help!!
Bruce
Bruce
