What? You mean that in addition to being a dispatcher, switch-man, and engineer I have to be a fireman too?
That explains some of the nebulous results I've been seeing. I have all sorts of numbers relating to how the tender and engine interact but I won't go into them now other than to note that all the engines appear to receive some volume of fuel/water at start up from the tenders and that, if the tenders are empty at start up, the engines still have some volume of fuel/water. Most are capable of going about 4 miles on an empty tender. I also verified that, according to the engine info, the auto fireman is set to false on all engines and I found that there are two different info displays, probably relating to different Trainz builds.
Sorting all that out is rather boring so, for fun, I tried hauling some full ore cars. I started out with the Texas and there is no doubt that the mass of the consist was affecting the "mileage" although not as much as I expected. A word about the route, about a mile from the starting point a mile long 1.5% grade begins followed by 14 miles of flat land followed by another grade which reaches, briefly, 2%. This is followed by down slope that hits -3% and, after a short flat span passes through the twenty mile mark. I started out with 20 full ore cars and was only able to get about 1.2 miles or, in other words, about two tenths of a mile up the grade. Several retries with decreasing numbers of cars eventually resulted in the Texas finally making the grade with 13 cars at about 5mph. Once I got to the flat the speed topped out at 25mph and remained at there for some 8 miles or so. Then, for no apparent reason, the top speed dropped to 16mph. It appeared that there might have been enough fuel/water to make the 20 mile marker but the engine hit the second grade and just could not pull the string over it. I did note that during this entire time the boiler and steam box pressures were steadily dropping, do you suppose the Texas was able to go 33 miles without me pitching a single shovel full of fuel?
All very confusing but I'm going to continue fooling around collecting data and I'm looking forward to using the various engines to haul the ore up the grade. I expect great things from Curtis' Mogul as it was the only engine able to accelerate the coach consist on the grade.
