2009 track
2009 track
I figured I start a thread here for the 2009 track I'm working on. Here's a shot of some 60lb bridgetrack:
This has rail joints built in, so they will appear automagically every 32 feet or so (should be every 30', but 32' makes the numbers work out much better in Trainz).
Knock on wood, I'll have the standard track finished up shortly, as well as a little bridge for this track...
Re: 2009 track
A 25 foot trestle, using the new '09 track...
zues
Re: 2009 track
Post by zues »
Could you make a 30in gauge version of this track?
meconicuk
Re: 2009 track
Post by meconicuk »
Both the bridge and track look good.
Mac.
Mac.
Re: 2009 track
Thanks, Mac!
zues wrote:Could you make a 30in gauge version of this track?
Someday I'll upgrade my 30" stuff to '09 standards, but it may take a while. I'm going back and forth between new stuff and updating old stuff. The 0-4-0 Porters will likely be the next 30" stuff upgraded to '09 standards.
jayo
Re: 2009 track
Post by jayo »
I hope bdaneal will also upgrade his engines! I know he's not really into adjusting what he's made, but still... :roll:
Re: 2009 track
A small culvert:
Zues,
While it's not the high-detailed track shown here, I did just put some ng30 bridge track on the DLS, matching textures provided by Ken.
zues
Re: 2009 track
Post by zues »
Pencil wrote:A small culvert:
Zues,
Ok
Re: 2009 track
Some more shots:
60lb well-maintained track with grey ballast
A small bridge sutible for crossing a ditch, or for use as a cattle guard
Two can be placed side-by-side for double-tracked lines
A small iron turntable
Shortline2
Location: Stuck in Norway, wish I was in the Netherlands - borned/raised in Norway...
Re: 2009 track
Post by Shortline2 »
Nice, very nice look!
I'm glad to see the useful track building stuff new for TS2009 being explored, I think you done great job her Curtis just by looking at the pictures and using earlier experiences with your stuff - but I've downloaded the track too so will have a walk around and over it in Trainz too one of these days.
Your use of a second fill spline has made me rethink some of my old stuff and techniques, and if I ever get back in creating track again I'm going for the same thing as it will simulate some of the track work along the Short Line (Gold Camp Road in Colorado) much better then build it all into one spline.
Thank you for dong this job, I will look at your track for inspiration next time. :D
Best wishes from Norway
Linda
Re: 2009 track
Thank you Linda!
I was originally going to combine the fill with the track like we did earlier, but decided to use separate splines for two reasons. First is that Auran is emphasizing the spline ends to 'close' the end of a spline. I noticed those would extend through the abutments of the bridges / turntables / etc that I was playing with. Second was that with multiple types of track with multiple ballast colors and multiple fill textures, it seems like the combinations would expand rapidly past a manageable number.
And besides, when you add the fill spline separately, it's not as perfect :)
I'm looking forward to seeing what you come up with!
