57' Iron Turntables
57' Iron Turntables
Post by Dreadnought1 »
I don't know whether this has been mentioned before (but I did do a quick search of the forum) so apologies if it has...
I placed one of the 57-footer TTs on a layout (it was the 3ft version) only to notice that the lead tracks other than the main entry/exit are off-center.
The further they are from the main lead, the further they point away from the center of the turntable.
I then loaded up the versions in the other gauges and found they had the same issue.
Re: 57' Iron Turntables
You are correct! No-one has ever mentioned that (and I had never noticed before, either!)
I hope I'm not pushing things too far but as we're revisiting the 57-footers, any chance of a version with only the main entrance/exit leads (just one on each side) please?
It'd be useful for those small depots/termini without a shed. The 57's are just the ticket for those shortlines!
Thanks & Cheers!
Sure, I'll add that to the list :)
edit: which gauge(s) are you looking for?
edit 2: it looks like I can fix the turntables, but it will break any routes that are depending on them - the track will need to be re-connected. I think I'll do a new (fixed) version with more detail, and mark it as 2.9 - that way it won't break any existing routes. How does that sound?
Sounds good - I like your thinking!
As for gauges, 30", 36" and SG if that's OK...
OK, here's a new set of turntables:
http://carsoncarshops.com/files/turntable_test.cdp
These are iron turntables, but a slightly updated model than what I used for the 57' ones. These ones are 65' long, and should fit Ben's generic locos a bit better. I did a single track and an 8 track version in 30", 36", and standard gauge. Please let me know how they work, and if the pit ground texture will work.
Look good and work well. The pit texture is also good to match up with a lot of the textures I'd use.
Thanks & Cheers!
OK cool! I'll stick them on the DLS, then.
