First Project
Re: First Project
And, if you like this one, we don't have one in 3 foot narrow gauge that looks like this sooooo,
040 in wood.jpg (117.35 KiB) Viewed 53122 times
Hint hint... LOL
smokeygear
Re: First Project
Post by smokeygear »
We'll see
Salutations
PO3 Darby
smokeygear
Re: First Project
Ok. Umm, Pencil I found out how to convert the box in question to an editable mesh. So how do you change the vertices once it has been converted, because I cannot find the right button for crap.
Salutations
PO3 Darby
Re: First Project
You'll choose the vertex option under selection:
Image Image
It's the 3 dots highlighted in the 2nd picture. Then use the move tool to select and move the appropriate vertexes.
(pictures stolen from http://www.vmbollig.de/msts/tut_en/cons ... ion_1.html)
smokeygear
Re: First Project
Ok. Thanks for the help.
Salutations
PO3 Darby
smokeygear
Re: First Project
Ok. Yah Its another help request. :| This time I want to know how to take a picture of what I have in GMAX and turn it into an image file so I can upload it here.
Salutations
PO3 Darby
Re: First Project
IrfanView will do it. I also use GadwinPrintScreen. They are both free.
smokeygear
Re: First Project
Thx again for the help. But I ran into another problem (it never ends) :x The screenshot is too big to fit on the board how to I fix that.
Salutations
PO3 Darby
Re: First Project
IrfanView will fix it. It'll make it any size you want it. GadwinPrintScreen will also fix it. They'll make any pic any size you want.
800x600 is usually the max size most forum boards will allow, btw, so you can gage your pictures to that guide line or smaller...
smokeygear
Re: First Project
Ok. I finally got it. Let me test this out.
Salutations
PO3 Darby
smokeygear
Re: First Project
Salutations
PO3 Darby
smokeygear
Re: First Project
Salutations
PO3 Darby
smokeygear
Re: First Project
Salutations
PO3 Darby
smokeygear
Re: First Project
I made the images big so many of you can see any mistakes or faults I might have made. I am open to CREATIVE criticizimes. :D
Salutations
PO3 Darby
Re: First Project
Looking good so far!
Your side sills look to be a bit small - the prototype sizes were around 9-12" tall and 4-5" thick.
This might be a bit of a nit-pick, but the truss rods don't actually bury themselves into the sills. They run alongside and then through the end sill, terminating in a large bolt. You can kind of see that in this model: http://members.fortunecity.com/gknowles ... _car_3.jpg
Hope that helps, and I look forward to seeing your progress!
