No more Willie?!?! I like the new guy, too, btw.
EDIT: I don't usually drive in Cab Mode but I will say this, WOW! that was fun...
The water sure gets used up quickly. Sheesh...
firebox-volume 325
firebox-to-boiler-heat-flow 0.01
firebox-efficiency 0.2
boiler-volume 3000
minimum-volume 2800
maximum-volume 2960
initial-boiler-temperature 389
water-injector-rate 1.9
westinghouse-volume 20
main-reservoir-volume 92
piston-volume-min 0.613
piston-volume-max 9.28
piston-area 0.0119
piston-angular-offsets 0.0174,1.5254,3.0333,4.5413
piston-to-atmosphere-flow 0.0004
boiler-to-piston-flow 0.0013
firebox-to-boiler-heat-flow-idle 0.003
burn-rate-idle 0.003
safety-valve-low-pressure 1205
safety-valve-low-flow 0.0035
safety-valve-high-pressure 1235
safety-valve-high-flow 0.2
max-fire-coal-mass 48
max-fire-temperature 1325
shovel-coal-mass 2.25
burn-rate 0.065
fuel-energy 25.5
