I just installed TRS'04 Deluxe Edition and haven't run it yet.
1. Will '04 auto update?
2. If not, can someone give me links?
3. Do I have to refrain from running it as '06 requires before I update?
4. Will someone please guide me through the process of upgrading '04?
Thanks in advance,
Need to ask questions about upgrading '04.
You do not need to refrain from running '04 before you install the service pack. In fact, you'll probably need to run it once to get your build number, as different build numbers require different downloads.
To install the service pack, go to http://www.auran.com/TRS2004/ and click on the service pack link at the top of the page.
Followed links and found that I'm patched just file.
My menu says;
version 2.4
build 2365
I guess I'm good to go...
My menu says;
version 2.4
build 2365
