				Couplers missing
				Posted: Sat Nov 17, 2007 10:23 am
				by jayo
				Hey pencie, when I downloaded your cars, they show up on the railyard, but they don't have the couplers.  I can't find the couplers on the DLS either.  Where do I get the link and pin couplers?
				Posted: Sat Nov 17, 2007 2:07 pm
				DLS, KUID2s:  63290:25011:2 and 63290:25012:2
				Posted: Sat Nov 17, 2007 5:33 pm
				by jayo
				I downloaded them, and the assets say nothing's wrong, but the couplers still don't show up.
				Posted: Sat Nov 17, 2007 9:01 pm
				Which cars are you having the problems with?  Also, which version of Trainz are you using?
				Posted: Sun Nov 18, 2007 10:23 am
				by jayo
				The V&T cars and the W&A passenger cars.  I'm using Trainz Classics.
				Posted: Sun Nov 18, 2007 10:39 am
				Ah, that explains it - Trainz Classics changed / broke the way some things are handled.  I'm kinda waiting to see if they fix it in a patch or in TC3, or if I need to redo everything for TC.....
For a workaround, find these lines in the config file:
		att			"a.couplerA"
and
		att			"a.couplerB"
change those by adding a :cull at the end, so they would look like:
		att			"a.couplerA:cull"
and
		att			"a.couplerB:cull"
now, these changes will break the config in earlier versions of TRS, so only do it for Classics.
Also, I don't have Classics yet myself, so this is based on experiments others have tried, and *should* work.
Good luck, and let me know if you still have problems.
				Posted: Sun Nov 18, 2007 10:57 am
				by jayo
				Nope, the couplers still don't show up.
				Posted: Sun Nov 18, 2007 2:42 pm
				OK - I'm not sure what to tell you to try, then.  I'll have a copy of Classics in a couple months, and should be able to troubleshoot the problems then.
				Posted: Sun Nov 18, 2007 5:47 pm
				by jayo
				I should note, the Old time flatcars' couplers do show up, but the other cars' ones don't.
				Posted: Mon Dec 31, 2007 10:59 pm
				Try :Cull instead of :cull - it looks like it's case-sensitive.
The flatcars are an older model with built-in couplers, so they don't have this issue.
				Posted: Tue Jan 01, 2008 8:36 am
				by jayo
				That worked!  YAY!
				Posted: Tue Jan 01, 2008 2:52 pm
				Excellent news!  If you run into any other problems with TC, let me know and I'll get you a work-around.
				Posted: Tue Jan 01, 2008 4:04 pm
				by jayo
				Actually, there is another.  When I installed Ben's docksider and NG mogul, I have a similar issue, except it's where the wheels aren't showing up, and the engine frame and boiler appear to be hovering in mid-air.  And again, nothing's missing and cmp says nothings wrong...
				Re: Couplers missing
				Posted: Sat Aug 16, 2008 8:29 am
				by jayo
				I have Trainz Classics 3 now, and I love it!!
   Best one since TRS2004!  Best of all, I no longer have this issue!  The couplers are always there!
