Mogul
Mogul
I tried to downlode the V&T Mougul 4 Virgnia but it will not show up in my TRS2009 Game if you can help with this i would be very happy to get it on my game.
Thanks Again.
Thanks Again.
Re: Mogul
Yes there is at lease two missing dependencies on CM2.
Re: Mogul
Ok- There is a Faulty on the Mogul Cabin Shell, And there is a Faulty Dependencies on the Mogul Interior and also there is a Missing Dependencies on the V&T Loco 4 and that should be it.
Re: Mogul
OK, the faulty on the cabin shell is likely the underlying issue; fix that and the issue should go away.
Unfortunately, I'm not seeing an error on my machine.
Can you tell me what error you are seeing, and which build of Trainz '09 you are running?
Re: Mogul
Ok, so how do i fix the shadow on the Cabin Shell.
And the errors that im seeing is that i can see the tender in full on the game but the loco is invisible in the game.
And the Trainz version is 2.9 (build 37625) thanks again
Re: Mogul
OK, try installing SP1 for '09 - the link is http://download.ts2009.com/patch/37625_to_38599.exe
Re: Mogul
Ok, i did what should do now
Re: Mogul
Thanks Curtis, i got it working on my game now thanks again
Re: Mogul
Thanks so much for the help with my problem , and i was thinking when are you going to let the carson out
Re: Mogul
The Carson will be a minor update - basically just a reskin, so hopefully not *too* long. I'd also like to do two more versions of Virginia - one with relatively the same paint scheme and color, but with the switcher pilot, and one in the later brown scheme that Inyo is currently painted in. Then, there's the rest of the early Baldwin moguls......
Re: Mogul
Ok nice,
I can't wait till all the moguls come out and can you also try to let them out in 06 form and are you going to do all the V&T locos
Re: Mogul
I have no plans to redo them for '06 or earlier; I'd rather use the time to work on new models or the route itself. I expect most of the V&T locos will be completed at some point in time, although not all by me. Bdaneal has created three of the 4-4-0's, and Terry is working on the two 2-4-0's.
The ones I'm currently working on are 4,5,6,7,8,10,13, and 14; which were more-or-less identical moguls.
