Site is up and (mostly) funtional!
Gallery is still having problems; hopefully I can get it working before too long
Prowler901
- Contact:
Thanks, Todd!!
You, Ben, and Linda all now have admin access to the site, so you should be able to add / remove forums, albums, etc. Feel free to make whatever changes you'd like - if you'd like to set up a forum for the San Juan Locomotive works, for example, go right ahead
I'm still working on tying all the different pages togather a little better - same visual style, etc. I don't really know what I'm doing, so it's kinda fun to learn as I go along (never let a hardware engineer play with software
Re: Site is up and (mostly) funtional!
Everything does look good but, why does it take so long to access everything??? It has sometimes taken me as much as 5 minutes to log in and then more minutes, not seconds, to switch to and, post to threads.
Every time I'm about to submit a trouble ticket to the host, the issue clears itself up again. Probably some other user hogging processor power, as it only seems to be an issue with php scripts - direct links and http pages seem to load fine.
It certainly is frustrating, though......
She sure is flying tonight. Whatever you did worked, Curtis.
